DMFD-Minister
- Jan 14, 2008
I'm pretty confused at the moment, so hoping there is an easy setting somewhere to disable. I'm also not super experienced with overclocking, I dabbled around with it on a 955 and I have read plenty of guides, but I would rate my level of experience as novice (trying to learn).
So I have the following config:
Asrock Z68 Fatal1ty Gen 3
Intel 2500K
8GB G. Skill Sniper 1.25v
1050W Ultra X4 PSU
Everything is under water. Stock idle temps for 2500k are between 25 and 29 Celsius depending on the core. Currently with Prime 95 running, I'm seeing load temps between 45 and 50 Celsius depending on the core. I am using CPU-Z and AIDA64 to monitor my system.
My issue is this:
I'm trying to achieve 5.0Ghz+ overclock. I figured I'd shoot for 4.8 first. I'm able to boot into windows at a number of various voltages, but finally have settled on 1.375 or 1.385. My issue is that whenever I test prime95, I go from 1600mhz to 4790mhz and then the CPU starts throttling. It'll drop the vCore to 1.29 and my multiplier to 42/43. It's literally bouncing all over the place and I don't understand it. Raising the voltages hasn't stabilized it thus far, and I can't really find anyone else experiencing the same thing.
I'm beginning to wonder if "Turbo" is kicking in somewhere and screwing things up. I like the idea of the processor being all efficient and whatnot, just want it running at 4800Mhz when it's in use.
Can anyone shed light on this? Let me know if I can provide any additional detail.
Intel 2500K
1050W Ultra X4 PSU
My issue is this:
