Overclocking 2500 mobile on Abit KD7
neokeelo
2 quick questions.
1. I updated my kd7 bios to the newest one but my motherboard still does not know it is a 2500 Mobile. It just says unrecognized cpu. Is this Normal?
2. I am trying to OC a AMD 2500 Mobile on this KD7 motherboard. I have OC Intel alot but never AMD.
what is a good voltage, FSB and ratio to run if I want to hit 2.2 Ghz (3200 speeds)
I have tired a few but have not had a succesful boot. Also do I need to mess with the ram settings any?
I am using 1 stick of Corsair PC3200.
Try 11x200 at 1.75v
And I don't know too many mobo's that identify it as a mobile chip. My board says its a K7 running at 2500 mhz on bootup
Yeah, your mobo won't ID the Barton as a Barton. Don't worry though...it''ll work fine.
neokeelo said:
do I have to changet the ram settings any? Like under Dram options?
Nah leave it as default, it should detect the timings alright. If it doesn't just find out what timings the default is (Corsair's website or newegg) and just set it to that.
