ghost_adsf
- Aug 16, 2004
I'm just curious if anyone here running one of these boards has verified the latest bios reads temps correctly. Currently I have my 2800@1.8ghz stock running 2800@1926mhz. First day of overclocking it, taking it slow.
Temps look good but I'm worried after reading thru these and other forums with information about overclocking amd64's, because I've read alot of the mobo's have issues with displaying the correct temps even with the latest versions of their bios.
Also if you want to add your current oc speed, if you have the same board and cpu. And also what temps you get I wouldn't mind at all.
Also note I'm running the stock HSF with stock thermal paste running @ a decently cool 53c on 100% load atm.
EDIT: Rephrased so it didn't look like I said only post your oc speed if you _also_ had the same temps. Heh. Lower temps would also be nice. +)
