I can't seem to find this online. How much faster does a system get when you're running at say DDR500 instead of DDR400. Also, is faster ram better than ram with tighter settings? Thanks.
In my experiences, Intel based systems favor higher FSB while AMD based system favor tighter timings. I have PC4200 in my system that can run 1:1 at 271FSB, I get like 6.4gb/s in sisoft, but in order to run at 3.4ghz I need to use a 5:4 divider that takes that speed down to about 6.0-6.1gb/s.
Of coarse this is all with DDR1, I have no idea about DDR2.
So nobody has any really concrete data about how much faster ram might be. Why would anyone avoid using a divider on their memory clock if the ram will be no more of less fast?
I have got Corsair DDR400 that runs at DDR480 $200 at newegg 3-3-3-5. I get much better in game benchmarks on my 4400 x2 at DDR480 than I do at DDR400 2-2-2-5. In my case the extra speeds seems to help.
I'm sure the faster memory will help but I don't think it'd be worth $250-$300. What kind of memory are you looking at that costs that much? I've seen 2x1GB of DDR 500 for under $200.
What is the reset of your system? The money might be better spent elsewhere.
