Overclocked AMD Dell! It works!
shoeish
So I bought a cheap Dell Dimension 521 for my home theater. Athlon X2 3800, 1gb RAM, so on. Turns out it is a *very* nice machine. SATA everything, the fast Seagate 7200.9 160gb drive (73mb/sec on hdtune), and the main reason I bought it, its dead silent.
Once I got Vista Home Basic stripped off for a version of XP and got my media software running, I decided to see if ClockGen would work. It did!
I haven't pushed it yet, but I have 2200mhz running solid with NO effort at all.
http://valid.x86-secret.com/show_oc?id=181222
ram clock speed is like 368 should be 400 should it? my sig pc has no bios functions and the ram only runs at 385.
I wonder if this will work with the Dell E520 Dual Core 2 Duo's? Any help would be appreciated...
k, going to try it. Is there a manual or guide for this app or tips from you since its a dell pc?
