Overclocked 2500+'s Statistics Here...
bobsaget
I want to overclock my 2500+. I want to keep the stock heatsink and fan. I will have many fans in my case so that should help a little. So if you have kept your stock heatsink and fan and have overclocked your 2500+, put your multiplier and FSB numbers here please!
Thank you so much!
I have the AVC stock HS/Fan combo. 200x11 at stock voltages. 45*C load.
Edit: Forgot to mention I am using the thermal pad, I didn't feel like taking that sticky piece of shit off and applying AS5. Have to do that here soon...
Locked 2500+@200x11 42C with AS3 and a cheapo OCZ Gladiator3 heatsink. Voltage at 1.75
Two 2500+'s at 1.65V
One with a locked multi the other unlocked
Running on ABIT NF7-S's
With SLK-800a's
Artic Silver 3
Kingston X 3200 RAm @ CAS 2(One running @2.8V)
11x200
MAx temps are 107F on one
and 120 on the other.
Some get lucky and still get unlocked chips. But the supply is running low. Seemingly all are locked now.
Chip specs. 2500+ @ 3200+ 1.75v (my psu sucks so I have to have it a little high because it dips a bit.)
I think is it a week 41 aqyfa.
Runs 23xx at 1.80-1.85 had it at 2508 in windows at 1.9 unstable.
2.2ghz load temps on stock cooler were about 46, with zalman 7000a alcu load is 38-39.
my 2500 is a week 50 donno steping but it is in a friends comp since his 2600 died
most i've ever gone is 205x12 for 2460mhz at 1.75 volts... my psu craps out after that, cause i put it to 1.8 and it's not stable... go figure
and i'm not quite sure what the temps were on that... i think i had about 40-45 idle and 55-60 load, slk-900a with factory themal paste and a 92mm case fan from an old dell
2500+@11x200 and 1.7 volts using the stock heat sink, here.
Mine's one of the older unlocked ones, but I just can't get it stable above 2.2 ghz no matter the voltages for either core, dimm or chipset or variation of FSB. However it's 100% stable as-is, so that's good enough for me.
Originally posted by JakeX
I think he said AMD 2500+ only :p
___ check sig!
V
sry i changed it yesterday
my 2500 is week 50. forget the stepping
Barton 2500+ week 31 (I think). Mine used to run at 11.0x200 at 1.8V, but now it doesn't run stabily at that speed anymore. Right now I'm running at 10.5x200 ~ 2100MHz @ 1.675V. Not exactly sure why my chip took such an incredible jump in voltage to get it to 11.0x200, but oh well--it doesn't matter since it won't run at that speed anymore anyways.
Shuttle SN45G with a Swiftech MCX-370CR2 HSF and Delta 38 60mm fan. Idles at 42C at 7V and 39C at full. Case temp is 31C, but will go down to 29C if I turn up the 80mm Tornado... Ambient is about 25C.
