how does the Gigabyte - 7NNXP with amd 2500+ overclock?
and whats the deal with locked and unlocked with this board?
cause i dont know if my processor is locked or not..
ok look at the cpu and read the identifying code on the top of it
look at the last series of numbers there are 4 digits in the number they usually (correct me if I am wrong) start with the year and then week- example I shall use my cpu
I will list the entire code off and then tell you what to look at:
AXDA 2500 DKV4D Y864787250654 AQXEA 0330 VPMW
ok, the numbers you want to look at are here |____| in this case 0330 - or year 2003, week 30. This cpu was built before the multiplier lock started. now if your cpu date is later than 0339 or so (2003,39th week) then your cpu is locked. But if that is the case do not fret too much as you probably will be able to raise the front side bus while keeping the multiplier the same - I bet you will be able to get 11x 200 (as 11x is the multiplier for a 2500+ barton) which is the equivalent to the 3200+ barton...
As for those that know a bit more, yes this is the imfamous "Grey Core" barton. Known due to the grey color of the coating over the core of the cpu and known to be one of the better overclockable cores. Had I known this when I bought it I'd a bought a tone of them. As with weak cooling and no overvolt she'll do 11x200 and the core temps have not increased over stock 11x166... Now if only I can afford some decent cooling....
