Overclock won't stick
Thin Man
I'm trying to OC my AM2 4400+ from 2.2Ghz to 2.4Ghz, just to start out.
I'm using the ASUS M2N32-SLI mobo, Cosair 6400C4, and of course the 4400+. I know I need to up the FSB from 200 to 218 to achieve this OC, I've done so in nTune. However, whenever I turn the computer off, the processor will revert to 2.2Ghz. I don't see any option in the BIOS to change the FSB and I figured nTune would work well enough.
Any thoughts?
Found it. It's in JumperFree Config and then you have to put it to manual OC and change the CPU Freq to 218. Thanks for the help :)
Any ideas though why the OC wouldn't stick through nTune?
Because nTune isn't really meant for real OCing. The only way is through the BIOS.
