Qwertyman said:ERROR: ILLEGAL SUMOUT
Possible hardware failure, consult readme.txt file, restarting test.
acascianelli said:you people dont take a hint when you start getting errors like this do you? when your processor cant add numbers correctly theres a problem.
Qwertyman said:well duh i know there's a problem thats why i'm asking this board for help to fix, 1) should i clock back down to stop, 2) should i leave it as it even though i do get runtime errors on UT2k4 if i play for a while because it doesn't do Math. 3) should i tweak my settings a little more i'm at 193x11 at 1.775v on a MSI board with the latest bios. Thats why i'm asking for your help not for an argument because i know its not stable as to reason i wanted to run prime to test.
Qwertyman said:[Mon Jun 14 08:25:56 2004]
Self-test 8K passed!
FATAL ERROR: Rounding was 0.4999694824, expected less than 0.4
Hardware failure detected, consult stress.txt file.
RancidWAnnaRIot said:One more thing.. is it safe to go up to Vcore = 1.85V ?? with the 2500+ that is..
CentronMe said:God I hope none of you guys that think you dont need to be Prime95 stable are folding, searching for ET or a some drug.
MemoryInAGarden said:I'm not a tremendous believer in Prime. I've had this chip pass hours of Prime at 3.2 ghz 1:1, and it wouldn't play 15 mins of Quake 3 without a CTD. Now 3.15 1:1 is both prime and game stable, so I use that as my day-to-day clock speed. While I can run 3.25 5:4 prime and game stable, the 3.15 1:1 generally gives better performance.
PhattyT said:ummm im a noob and was wondering where yall dl P95?![]()
Qwertyman said:no it blows, its a 2500+ not a 2600 its wrong in my sign i will change later though. i don't know why its being a bitch i've been try to get a stable overclock for about 3 weeks already. MSI YOU SUCK!
RancidWAnnaRIot said:Ok.. seems like the fan has a screwy yellow signal wire.. all other fans work great on the same fan connector...I'm probably just gonna replace the fan sometime soon so back to OCing!!! but before i do..
These are the RAM timings i'm getting from the BIOS..
SDRAm active Precharge delay = 8
RAS to CAS delay = 4
SDRAM RAS precharge delay =4
CAS latency = 2.5T
would this timing read as 8-4-4-2.5T ??? in what order do you label these things.. also.. do these timings sound reasonable for the overclock i'm trying to get to..
This time I'm just gonna up the voltage to 1.75.. i was on 1.700 when it failed prime after 18 hours and 10... let's see what happens.. i will post my result
