I have been overclocking the rig in my sig. I got it up to 2.6Ghz, 10 x 260, 1:1 ratio, CPU 1.45v / RAM 2.8v / 2.5-3-3-8. Had to turn HTT link down to 1x, or else I couldn't get into windows. With these settings, it was Prime95 stable, and would handle any benchmark I threw at it like PC Wizard, 3DMark 05/06, Everest, etc. But when I would load up FEAR Combat, once a map loaded, it would run smooth for a bit then freez up and BSOD. I tried Half-Life 2 and it runs fine. I also discovered recently that it does the same thing in Quake 4. My temps are well within reason, 27-30C Idle / 42-45C Load(gaming) / 55C Max. under Prime95. I cheked my video card and it is not the problem. I just bought this RAM and it is rated for 250, so I assumed it would do at least 260 no problem. I tried setting the latency to 3, but it didn't help. Maybe I need to tweak the timings? I have heard of X2 3800's doing 2.9Ghz and even 3.0Ghz, so I was hoping I had a good one. Any help would be appreciated. I was wondering if maybe my PSU could be insufficient? It is a cheap no name that came with my case. I also tried setting the mem ratio different to try to determine if it was the CPU or the RAM, but didn't have much luck. I think I will try some more while I have a few hours. Thanx in advance...
