Overclock Tweaking
Nismo
Hey guys, just got the below stats stable. I now have 2 goals:
1) Clean up the below stats a bit (lower anything I can)
2) Get my RAM from 1200 back to rated specs of 1333)
-If I change my RAM, what else increases with it? PCI? Whats the best way to get it back to rated speeds?
-Should I go higher with Uncore? Is there a benefit or would it cause stability issues?
-Anything look off with the below stats?
i7-920 @ 4GHz (Idle 32c, Load 58c)
Zalman CNSP10x
Gigabyte GA-X58A-U3DR
OCZ Gold, 6GB
CPU CLock: 20x
QPI Clock: Auto (7.2)
Uncore Clock: x13
Uncore Frequency: 2600MHz
BCLK: 200
PCIe Freq: Auto
Performance Enhance: Turbo
SPD: 6.0 (8.0 takes it to 1600)
Dram Timing: Auto
Load-Line Calibration: Standard
CPU Vcore: 1.3v
QPI/Vtt: 1.34v
IOH Core: Auto
DRAM Voltage: Auto
CPU PLL: 1.98v
