Overclock the x1300 PRO
MrHuk
Having some problems atm, I usually use ATI Tool but it doesn't seem to work with this card, no numbers show in the core/mem. And when I try and use the software that came with Omega Drivers I get some error like "Unable to retrive info from bios"....
Does anyone knows what's up? Or is there some other software I can try?
Thanks.
are you using the .25 beta? or .24? try the .25 . and post ur overclock luck this sounds interesting.
Umm, well. With stock cooling I got like a 40mhz increase on the core and it says the memory can't be changed on this chipset.
lol i guess its already too high......... owell still a good card.
