Overclock suggestion for i7 920?
boshunter
I recently built an i7 system for work (and some games like Crysis and Fallout 3)
I mainly use Maya, Aftereffect, Photoshop.
My current system:
Intel i7 920
Asus P6T
OCZ 6gb DDR3 1600 Gold
BFG GTX260 Maxcore
CoolerMaster V8
CoolerMaster HAF 932
Corsair tx750
2x 500gb WD Black raid0
I am pretty new to PC, been a Mac user.
So I don't know anything about overclocking
I read up on the overclocking thread but I dont really understand it.
With the CM V8 @ stock speed
I get avg 37c idle and 50c at max load with prime (fan @ 1400rpm)
I would like to know whats the best setting to use in bios to get about 3.6 - 4.0 ghz
and would those speed be stable enough for work
these settings I am stable at 3.6 with a 920 cooled via CM V8 (msi eclipse mobo)
base clock 180x20 3600mhz @ 1.23v (+0.10)
ratio ram 4 > 1440 (auto vdimm)
qpi voltage auto
qpi > full speed 4.8 GT
intel eist > auto
intel turbo boost > disable
spread spectrum > disable
ICH voltage > 1.1v
IOH voltage > 1.1v
with fan on full, load temps are under 60c (57c ish range) and idle are around 30c
Ok, I followed the video setting.
The system start up fine, boot to win 64 without problem
But the system froze after 5min of running prime
idle temp 40c, load temp 70c
I am not sure, maybe is the memory timing?
I am using the OCZ 1600 Gold edition
I think the timing is 8-8-8-24.. (no idea how to read it)
or maybe my cpu can't handle 3.8 oc
Thank for the help
