I have been toying with an i7-2600K and an ASUS P8Z68-V Pro for a few days.
Obviously, with an unlocked multiplier, you can fool around with these forever,
I don't have a need for a high overclock, am cooling with a Megahalems.
I prefer stability.
So far I have had solid results at 2 totally different overclocks, which both
pass all burn tests that I have thrown at it:
1.) 46 x 103 @ 1.375v = 4.74GHz turbo.
2.) 40 x 100 @ 1.150v = 4.00GHz turbo.
All the BIOS settings otherwise were virtually default, with a few integrated peripherals turned off.
Both the TPU and EPU switches were turned off on the ASUS, they both proved problematic.
CPUZ shows slightly lower voltages than those reported by the ASUS BIOS.
With #1 setup, adding any additional voltage did not yield a higher BClk or multiplier, so that would appear to be top-end for this setup.
With #2 setup, I was going for the lowest voltage that the setup would tolerate without failure.
Lowering the voltage below 1.150v failed, which is not surprising since that is a really low voltage,
about what I got with a Westmere Xeon E5620 recently.
What setup would you choose, and if the higher voltage, higher turbo #1, would that be only because it is a higher overclock?
I realize this is [Hard]|OCP and most people just want the fastest setup.
I am tempted to run the slower #2 setup since it is such a stunningly low voltage.
I realize that it is not much of an overclock at all, but 1.150v ???
Does anyone know what the default vCore is for the i7-2600K?
www.ark.intel.com
does not seem to list one.
Any opinions?
I prefer stability.
www.ark.intel.com
Any opinions?
