overclock nvidia 7900 gtx?
machu1
what do i need to overclock it
i got attitools. core clock600mhz memory800mhz?i would go higher but on the picture it shows snow and its not suppost to.to be stable it has to be clear.?help how do i over clock it more or is that good enought?
that might be as far as it will go.
What cooler are you using?
Is the card volt modded or stock?
You can try Riva Tuner, but you might end up with the same results.
I had my 7900GTX at 780/950...but it was watercooled, and volt modded;)
Try Rivatuner. When I had that card I ran it at 700/900 with no problems at all. Stock everything.
none just the card by itself with its fan and thats it. what is volt modded?what is stock?
mine is around there. i dont have the speeds right now.
i tried mine but the game on some parts would go grey.i guess its too high ill just put it at 700/800 or 700/700
Use nvidia ntune for monitoring...more safe! Isn't the 7900GTX card still considered to be one of the top gfx cards still? Or am I just daydreaming? lols....
oh ok.well i think so.my friend was like thats crazy when i said i had that video card.he was like wow.so i think yeah it is still good.
