I have a 9600gso (I know... it kind of sucks), and I'm trying to get the most out of it. It's an EVGA card, so it came with their "Precision" overclocking tool. I turned up the core clock, shader clock, and memory clock to the edge of stability and actually got 5-8 fps out of it, which makes me happy because it's the difference between 19fps and 27fps sometimes lol.
However, it seems as though once the card heats up, it's not exactly stable. After an hour or two of gaming, it will suddenly go black for 10 seconds or so and then return to normal. Once it's happened once, it happens every 10-15 mins or so. I do have a HUD showing my GPU temps, and they usually get to 70-72 C when it cuts out, and when it comes back it shows 65-68 C. Is this some sort of fail-safe overheating protection? I have an aftermarket cooler in transit right now, should be here in a couple days to test this.
I had an old, old GeForce 4 Ti 4200+ (Gainward Golden Sample) way back in the day which also came with an OC utility. When I cranked that one up a whole couple Mhz, it would actually display artifacts on the screen. It's been a while now, but I believe that was due to undervolting the vram...?
What do you think is going on with my 9600gso? Undervolting, overheating? I'm interested to see what you guys think.
