Overclock ATI using Rivatuner
Nirad9er
How do I overclock my mobility 9800 using rivatuner. I dont see any overclocking feature. Is there any automatic downclock to use with powerplay.
Could someone tell me how to do this? I know how to overclock the card with radlinker but I want something that will work with powerplay and reduce the clockspeed automatically when on battery a power. I was told rivatuner might have this feature.
Thanks
Alright im not postive about this, but I think Rivatuner is for Nvidia only? But I use ATITool for overclocking ATI. sry, dun know much about your battery power issue
i use rivatuner for my 9600. its the first button that comes up when you push "customize" in the main tab
I tried that but it only brought up the AGP settings. No overclocking stuff
It there a certain version I should use?
can anyone fill in the blanks.
Nvidia _____ TNT or Nivdia ____ 128.
Once you fill in the blanks hopefully a light will turn on.
edit: Wow I have been out of the loop, Guess now you can use it at least, don't know how usefull it is for ATI cards though. I believe there is a ATI tool though that would probably do a better job.
