Ch1m3r4 said:hi we need system specs.
meowCat said:i got a xp1700+ which runs upto 2,800mhz prime stable..
but mine is waterchilled.... and is dlt3c xpmw 0310 stepping... does about 2.4ghz@ 1.8v air.. so it's not the greatest.. but not bad.
hey you original poster, you also might have bad stepping of the chip.. that's gonna hurt your oc significantly...too. I take it's the tbred right? or is it Palomino? you need to tell us this... so we get an idea what range of clocks to expect@ X cooling & voltages...
so, go find what type of chip yours is.. as well as the stepping. then we'll talk.
sure hon...2Fresh said:I find that 2800 hard to believe...screen shots pls
meowCat said:sure hon...
that's.. with just waterchilled...
it goes higher, with my better cooling. you want sum?
Aminotaur said:i dont know if its in that order you tool, just stfu
This document from Mushkin outlines how tRAS should be a sum of tRCD, CAS, and 2. For example, if you are using a tRCD of 2 and a CAS of 2 on your RAM, then you should set tRAS to 6. At values lower than that theory would dictate lesser performance as well as catastrophic consequences for data integrity including hard drive addressing schemes --- truncation, data corruption, etc --- as a cycle or process would be ended before it's done.
