Over-volting a GPU - just as safe a CPU?
blade52x
Is raising the voltage on a GPU just as safe as raising the voltage on CPU if the temperatures are fine? I've never overclocked a video card beyond it's stock voltages. Right now my graphics card loads in the mid 60s, at 75% fan speed, however, I cannot go higher than 685/775 without getting lockups. With my temps in the mid 60s, I seem to have some head-room (As long as my GPU temperature stays under 75C, I would be happy).
What are your experiences with raising the voltage on the core and memory of a graphics card. Does it differ in anyway than raising the voltage on a cpu? And do temperature rocket after giving slight bumps in the voltage, or is it a gradual increase?
For some reason I just feel hesitant in raising the voltage on a $200 piece of hardware, yet I am perfectly comfortable raising the voltage on a $300 piece of hardware (probably because I've researched a lot more on that).
I have read that increasing the voltage to the agp or pci-e does not help with overclocks on the gpu and can harm the card. I would not do it... I have heard there are ways to increase the voltage not through the bios and that can help with overclocking... but honestly I would not think it would be worth it and could decrease the life of your card.
A slight bump can help and oc out slightly or just make the current overclock even better (less artifacts)
I bios modded my 7800GT's from 1.4 to 1.5 and temps didn't increase but my oc before was a maxed around 480/1200 (stock 445/1070) before artifacting, now with the bios mod i'm at 500/1200 no artifacts and could actually bump up the core a bit more (had it around 520/12230) with minimal artifacts, but keep 500/1200 to be safe.
So is it worth it, hell yeah, video cards depreciate too fast to not be o/cing, so unless you plan on keeping the card for 5 or so more years, why not?
volt mods rock, my old 9800se Type2(256 b bus) ->9700pro mod (found a volt mod howto online for that particular card) would attest to that. Stuck an 80mm fan on the stock heatsink and it was #1 on the 06(or was it 05?) benchmark list here in these forums for a long time, the 9800se type2 section. Still have it and it still works if I hadnt upgraded. It's my backup.
Volt mods are teh shit.
We're talking about upping the voltage on the GPU and RAM, not the PCI-E bus itself.
I raise my GPU voltage up between 0.1 and 0.5V and the ram a smaller amount. I would raise it and see if you can clock any higher without going over your temp limit or artifacting, and if it doesn't help, then I wouldn't raise it any higher.
You raise it .5 volts? That's a 33%+ increase no matter what card you have...
If you're going to over-volt it, I say stick to a .1v increase on the core, as I've read it is of the most value (gains:lifespan)
