Over Allocating Resources in ESXi
Jesse B
I'm currently in the process of building myself a dedicated ESXi box. Basically I just need to wait and see how things go financially (school sucks :D), and then buy the motherboard and memory; good to go otherwise. I'm also waiting on Chilly for the Intel drivers, so things kind of work out :D
Anyways, I've been kind of planning out what I'd like to run on this machine, and what kind of resources they require. Basically I'll be running a plain white-box with an i5-2500 (supports VT-d, so does the Q67 board I'm getting) and 16GB of RAM, and then some add-in cards.
Basically there's 3 VM's that I "need":
- File Server (OpenIndiana)
- Media Server (Some Linux distro)
- Web Server (Debian)
Between those three, I've allocated 6.5GB of RAM. With all the other VM's I'd like to run, I get up to about 18.5GB of RAM. I feel like this shouldn't be an issue with 16GB, but I'm just confirming.
The one thing I'm really unsure about is how I go about allocating cores. Ideally I'd like for most of the VM's (except a few) to have 2 cores, but doing this puts me up to 13 cores, which is obviously way over 4 :D Is this possible to do, or...?
I'll also be passing through a few PCI-e devices, but that's not really a huge issue.
Thanks,
- Jesse
Unless the guests burn enough cycles, stick with one core each until and unless you find a problem? Also, if you have VM tools installed on the guests, memory over-commit is not such a big deal (as long as you don't go too far overboard...)
Give a VM a single vCPU until it needs more and shows high CPU utilization in the guest.
