Ouya Console Running XBMC
Speaking of playback issues as noted in the video. I know it's an early alpha build of XBMC, but what was he talking about in regards to "libstagefright"?
I figure that's an encoding library of some kind. If you see in the video, certain 1080p videos encodes properly worked flawlessly, except for Buck Bunny. Maybe a bad encoding?
For a Tegra 3 machine, it looks to be a very nice, affordable media player. If you want something more robust, powerful and/or customized (i.e.- Plex, PVR, etc.), you would have to build it yourself. Those that can't do that or want something simple and straight to the point will settle just for the Ouya.
From what I understand android XBMC can't use hardware acceleration for specific devices for whatever reason and because of that it can’t play Hi Def videos.
Libstagefright is a generic way to get hardware acceleration that isn’t device specific and with it you can watch 1080p.
Or... you know... just let each client manage it's own DB after pointing it to the media space (NAS or the like). Really not a game changer here.
so then I have to fix whatever DB issues decide to appear on each client?
I can't keep track of what is watched/unwatched globally?
can't pause in the living room and resume in the bedroom or on my phone
cant stream to my phone because of bandwith limitations (plex re-encodes on the fly on server)
1. What "DB issues"? I have a self updating DB that auto updates/cleans itself every hour and there is never a problem.
2. Why would you want to? You don't remember if you've ever seen Star Wars before?
3. Personally, I think this is the height of laziness. Do you really need to move between places when watching something? If you really need too, you can't fathom one more click to where on the status bar the movie was?
4. I wonder if this would work for 1080p mkv's and sending it via wifi to an android device at full resolution.
I'm not putting down Plex at all. I think it's a great program, but for the reasons you have listed, they really aren't earth shattering like you're preaching they are. Just because you like it doesn't mean the people who use XBMC are godless heathens. Off your soap box.
1) DB issues would be like matching shows incorrectly etc...
2) I use it for TV shows more than movies so yes, I like for it to keep track of what I have watched and not watched, is it bad that an app has a feature I like?
3) yes, and if you were not lazy you would be using disks instead of a media PC app so this argument I do not understand... some of us have been blessed with more than one room we watch TV/Movies in... :p
4) well Plex IS based off of XBMC so presumably they would both be working on this... I don't use WiFi because its not fast enough for BR ISO's which all my movies are in hence my excitement at the inclusion of ethernet in the ouya
when did I say XBMC was not good? please don't put words in my mouth or suggest i am on a "soap box", I expressed my opinion and then you jumped down my throat...
I said of all the media PC apps I have used Plex has been the best... I used XBMC for years (used Boxee before XBMC)... but my Media PC's are not on all time time, hence why I like the centralized DB, which like I mentioned was possible in XBMC with mySQL
problem was every time there was an update to XBMC it would break everything and require you to export the DB on one machine, update all of them, then reimport the database and prey it worked...
1)problem was every time there was an update to XBMC it would break everything and require you to export the DB on one machine, update all of them, then reimport the database and prey it worked...
In this case you can't mix and match versions on xbmc because the client is linked to the database. So if you update all the clients to the same version, you would have zero problems. I use OpenELEC at my house in several rooms and I really like the extra flexability of XBMC vs. Plex. To Each Their Own.
Personally Im heavily considering this.
Ouya looks amazing for the price/features/support. Sure there are other android sticks out there, But this one looks like its really gaining ground and XBMC usage looks great. I was considering a ITX setup, but $100 vs $300 is a no brainer for me.
