outlook 2007
bigstusexy
Quick question
How can you send mail back to the inbox on the server? I've used outlook to do this before, actually now that I think about it that may have been outlook express and I know thunderbird, but usually it presents the inbox in the personal folders and you can see an inbox of the server under its name and just transfer it from personal folder inbox to server inbox but in this one (its setup POP3) I only see personal folders.
What is going on is that the user setup outlook on their on on their personal laptop and didn't check leave copy on server so now all their email is on a computer and not the server.
You will have to take the PST file that has the mail in it. Put it on a desktop that is connected vie exhange to outlook, (not POP3) and import them to the mailbox.
Would adding an exchange account to that install cause an issue? I thought about that as I was driving around. I could do it without adding it to that one however it would just be quicker doing it with out a second machine.
Thanks.
You should be able to do it on the same machine, just make sure you import to mailbox, not personal folders
