Outlook 2003 question...
kjm2003
Hello, Im am trying to figure out somethign here. I have two email accounts associated with Oulook 2003. But BOTH email's goto my inbox folder. I want to be able to assign 1 of the email addesses to a folder that I created. Is this a possibility in outlook?
Thanks,
kyle
It depends on the account types. You can only have one Exchange account. I use IMAP on all of my secondary accounts. This leaves the mail on the server in its own folder. I don't like using POP3 because of the problem you mentioned.
To directly answer your question, you could set up a filter for the "To" address.
yah just create a message rule for what ever account you want to change from the inbox and have it go into what ever folder you want.
Can you not do identities like in Outlook Express? It should if OE does, check and see for that maybe.
Aw, you guys kick ass...I did what spotdog told me to do, and it works perfect. Thanks again guys...
