Osmi Case
I highly doubt any AIO would fit in there, the space for the fan at the top is 26mm.
Maybe it would actually be a good idea to move the discussion about the Osmi over here, in a dedicated thread.
The other one was more about cases for ITX cards in general.
Maybe with slim fans? Doesn't sound likely though...
If mods would prefer to delete this thread or merge it with the other that's fine.
The slimmest AIO I know is the Silverstone TD03 SLIM which is 37mm including slim 15mm fans. You can get down to 32mm by swapping the fans for 10mm equivalents and maybe you could get another 1-2mm if you were to file the frame down so the fan gets recessed a little bit, but that's the slimmest you're going to get.
Interesting, will definitely look into that. I'm wondering how much of a performance hit there is using slim vs standard fans.
I know that people tried using a regular 25mm fan on the NH-L9 heatsink instead of the stock slim one and found out that it doesn't improve performance, make of that what you will.
