Os issue on install
Ok i had previously had a vista enterprise shit or something and i couldn't get it to activate at all . It eventually locked up after 30 days and i got a xp to install instead. I couldn't get the xp cd to load up in the locked windows so i did a boot from cd. It has installed and everything seems to be working fine except the fact i am now missing half of the space on my harddrive.My hardisk is 250 gbs and all i have on my xp hd is 127 gbs.It's kinda puzzling cus the other locked up vista must be on there somewhere along with all the music and other files i had on it.......My question is how do i erase my whole hardisc,and i mean everything just wipe it clean then i can start a real fresh install?
When you boot with the Windows XP CD you should have an option to delete and create new partitions and/or format them. The other way is to use a hard drive utility that is bootable on a CD/USB flash drive/floppy.
That probably means you did the install with a pre-SP1 XP disc, which can only see drives up to around 127 GB of space. There's no reason not to have a slipstreamed disc of SP2 or SP3 at this point, which would eliminate the problem.
However, depending on what processes you did before to get XP installed, you may have already deleted the music and files you had on the rest of the drive.
If you plan to do a fresh install of XP, get Autostreamer and the full SP3 install file, make yourself a new disc and boot from the new disc. You can delete and clear any partitions, and then let XP's installer use the entire drive.
Agreed, I did this myself recently.Installed from what turned out to be an original XP disk. Had to get an SP3 copy and start over.
i found it now and made a partition outta of it.Is there anyway to join it together with the main partition and make it just one drive?
