ComputerGeek
- Dec 27, 2010
Hey Guy's I am just about to finish up my Home Server Build, and had some Questions. I was wondering what you guy's would recommend for a Home Server / Backup Server OS. I would like to try to go with Linux. I have used Linux before several of the different versions mostly Ubuntu, I have done the No GUI OS's but I think I would like to have a GUI here.
2. I would like to make this accessible from anywhere if possible, Using Wake on Lan, and then some type of connection. The Connection I should use is really what I am unsure about. Will having a connection like this pose a Severe Security threat? What is the best way to Go about this? Does having an OS with a GUI make the OS less secure?
Thanks!
Thanks!
