I've been using beta, and will update to gold tonight. The only thing that blows my mind in 3.0 is stereo bluetooth. However, as of beta 5, the AVRCP profile had bad compatibility issues. I'm hoping that's fixed for the gold release.
What is bluetooth stereo anyways? I don't get how I would use it.
What build # was beta 5?
BT stereo is working pretty good now in the GM/Release.
How is the Stereo blue tooth for playing music? Does it work with Last.Fm and all that?
"accessing i-tunes store"
wait
wait
network connection timed out...
soooo, my phone is useless until they get their crap fixed... absurdities like this can only come from apple.
@Verge - Yeah, chill out. =P It was JUST released so you have, oh, how many tens of millions (they just announced, it was either 10 20 or 40...I forget which) of iPhone OS appliances out there? No matter how much you plan, that will take any system to it's knees. Wait an hour or two, try again.
It's not a world of warcraft update... its' a cellphone, that is rendered useless while they fix their servers.
Unacceptable, i should be able to use my phone without apple needing to intervene. This is just a software update.
you could NOT update right away. Not updating won't make your phone unusable. (double negative galore?)
Fixed my crawling speed issues that 2.2 created, so I'm happy there.
AT&T needs to DIAFF though. Their excuses are BS, Engadget is reporting that it's easy to turn on Tethering and MMS, and both work 100% fine in the US. AT&T is just trying to figure out how best to charge us for it.
Still waiting on activation server access. Ugh, ridiculous.
upgradeing from 2.2.1 to 3.0 forces an active phone to re activate? And as a result... your phone isn't work until it can get through?
Only downloading at 98k/s is gonna take forever to get this file. Now I just have to wait for the Jailbreak to be released and I am golden.
Landscape texting and MMS is all I am caring for.
This solution worked for me. Found it on Mac Rumors.
At the point at which the software is being extracted (assuming you have been able to download it) turn off your internet connection.
The software installation then proceeds without a problem.
At the point at which you get the message saying "can't connect to the itunes store" turn your internet connection back on.
I then had to eject the iphone and physically unplug the usb lead, then plugged back in and it has worked fine.
Not sure why it works but it does.
well, i got the OS to install by using the following instructions found HERE:
now, all this did was e-brick my phone. it installed the OS, but it will only allow for emergency calls now. so, now what?
