kent
- Apr 8, 2001
System:
Opteron 165 CCBBE 0617
MSI K8N Neo4-FI motherboard with latest BIOS
2x1GB Ultra DDR400
1 IDE HDD
2 IDE Opticals
X600SE PCI-E (don't ask...)
Antec TruePower Trio650 (Seasonic built)
Anyways, I've been Prime stable at stock voltage for 24 hours at the following speeds: 1.8GHz (duh, gotta make sure she works!), 2.2GHz, 2.5GHz, 2.6GHz
I bumped it up to 2.7GHz and I was curious of my temp when I only loaded up one core so I opened Orthos and in the Task Manager set the affinity to CPU 0 only and started Orthos.
It failed within a second.
So I let Orthos use both cores, it's ran for 5 minutes stressing both cores A-OK.
So I stopped it and reset the affinity to Core 0 only, again it failed within a second.
Reset affinity to Core 0+1, it's been running 5 minutes again.
Is this an Orthos error or what?
2x1GB Ultra DDR400
1 IDE HDD
2 IDE Opticals
Orthos using BOTH cores said:Using CPU #0
Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
Torture Test ran 5 minutes 28 seconds - 0 errors, 0 warnings.
Using CPU #1
Execution halted.
Execution halted.
Orthos using Core0 only said:Using CPU #0
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 0 minutes 3 seconds - 1 errors, 0 warnings.
Execution halted.
