Orthos blended/large issues
ianc
New system, built over xmas and I was going to start oc'ing but wanted to have some stock baseline numbers first. I can run the orthos "small" test for hours and TAT shows 44C. But when I try to run "large" or "blended", orthos will fail in 14 and 24 seconds respectively. Not only fail, but hardlock my system requiring the reset button. Large and blended test ram as well as cpu where small is cpu only, so logic would indicate that I have a ram issue. I have no floppy so is there a memtest method to check ram that doesn't require a floppy?
I have made bios changes for ram including upping the voltage to 1.2V (ocz rating) and set the timings to 5-5-5-12. Cpu-z was showing the timings as 5-5-5-15. Anybody else have issues running large/blended?
I need to update my bios version but with no floppy (and no experience doing it), I'll have to do the windows internet update which from what I've read here it not really recommended. Bite the bullet time maybe with a temporary, external floppy.
