Trying to OC my E4300. I've got it running at 8x334. Core is orthos stable, however as soon as I switch to blend, Orthos errors out.
The RAM I'm using is OCZ PC6400 Platinum Rev 2; no idea what the actual voltage is supposed to be since the OCZ page lists a range, but I've tried 1.8-2.1 and they all either crash or error out.
Could it be the FSB on the motherboard? The RAM is 800MHz and I'm running it at 668MHz so I highly doubt it's a RAM issue. I should note I had EIST and C1E on before and I had the FSB up to 350 with no problems, I Just went to 334 so I wouldn't have to adjust the CPU core. But it seems like I'm running things within or under spec and there's still crashing.
Anyone else having similar issues? Know a solution?
*edit* Using a gigabyte GA-965P-DS3; great board but doesn't show you how much voltage is going into anything, just how many volts over stock you can put them :T
