I have an original (well older version) Klipsch ProMedia 2.1. The left and right channels work perfectly. Really loud and clear. The subwoofer is a different story. I can have the sub control at any volume level but nothing is being outputted.
I took it apart this morning but didn't see anything obviously blown. Granted I'm not an electrical engineer do don't really know what to look for besides blown capacitors or fuses.
I'll add some photos later and I'll also hook the driver up to another sound system to see if it's just the driver. If do that would be a cheap and easy fix. If it's the amp I have no clue where to start.
Update: images added. Also tested driver in another system and it works fine so unfortunately it seems to be a problem with the amp. All fuses look good.
http://imgur.com/owdnLGp
http://imgur.com/Hc9tBCv
http://imgur.com/qvcpvxs
http://imgur.com/WSe46pL
http://imgur.com/x8tDv7a
http://imgur.com/dfDy5o8
Did a quick review and noticed that I also had scorched and broken zip ties. I guess something blew up in the amp . I'll have to look a lot closer.
Adding some more photos that might help...
http://imgur.com/vNlF1uv
http://imgur.com/jnRDiSu
http://imgur.com/yfGdeXV
http://imgur.com/WX1783G
http://imgur.com/BBshMIr
