Ordering either a Kandalf or Armor
FIDDYOWNZ
If I'm not mistaken, the side panels on Kandalf and Armor cases are the same. You should have the option of getting a Kandalf with a 25cm fan. If not, you can buy the side panel separately.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999812
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999811
Maybe Performance-PC's has that option...
::::: DID SOME SEARCHING:::::
Doesn't look like anyone offers that...also the Armor just got a $30 mir. :eek:
I sure like the Kandalf...but a $50 price hike for a lousy alum front bezel ... I'm not too sure. Any thoughts?
Performance-PCs does carry the doors, although the blue lighted fan version is OOS.
On that note though, I'd go for the Armor - better looking IMO. And remove the flaps - they were useless on mine (no magnets or something, common w/ the Armors apparently). They don't really seem to serve a purpose other than obstructing the optical bays. Loosen 4 screws and they're off. [edit] Oh and make sure you have a decent vacuum or something - the dust filters on the Armor catch a ton of crap...But then again I have 2 cats, and there's a big construction site down the street from me.
