Ordered PSU Sleeving Kit(Need Tips)
TheMagicalJew
Hey Guys I was wondering if you guys could give me some tips on Sleeving my antec 420W. I want it to turn out the best so i ordered 20 feet of cable :)
Thanks for all of your time
Julian
Hi,
Sorry if you already know these.
I found that braiding the cables first makes sleeving easier and neater. Another thing I found is that it's even cleaner (in my opinion) to hide some of your cabling (like the ones to power your hard drives) under the motherboard and it's easier to do so without the sleeving the cables.
Good luck.
One tip I've got is to wrap the pins in tape before trying to slip the sleeving over them, otherwise you risk catching the metal on the sleeving and messing it up. Also, mark or have some sort of reference for the pins to see that it all gets back together correctly.
The 2 black wires are ground right? If so, does it matter if they are crossed or not? I just got my sleeving kit and I stare at it wondering these things.
