Okay, so I have most of my components on the way for my system and I have a rather cramped case that I'm going to be fitting all of them into. The rad is up top on my 120mm blowhole, but the nozzles are on the end facing the PSU because my drives get in the way on the other end. Basically, I am looking at what could prove to be a rather difficult tubing job for all of this.
Is there any difference in performance based on the order of components? Originally I wanted to order it like this:
Pump -> Rad -> CPU -> Res -> Pump
But, this setup will be a lot easier to do with less drastic curves and such:
Rad -> Pump -> CPU -> Res -> Res
Any thoughts on if this will make a difference? I figure my flow rate will be a little better, but would the temp of the water going to the CPU be better if I had it coming direct from the rad? Is it worth a ton of extra work and such to get it to the first setup? Thanks for all the help, folks!
