Yup. If you've planned your system right (enough flow), your temps before and after a block should differ by less than a degree (~0.2C for a decent setup?).HeThatKnows said:The only flow ordering that is important is that the res be right before the pump (to help avoid cavitation). Other than that, whatever is easiest.
HeThatKnows said:100 watts into a gallon per minute gives a change of a hair under 0.4° C, not something you'd notice.
Well obviously the pump isn't gunna dump 100 watts in the water.Cathar said:Yes - but remember that the CPU block is doing that regardless - so what's really important here is what's raising the temperature of the water between the radiator and the CPU waterblock inlet. In the above case - the only difference is the pump. The actual difference for the CPU is more like 0.05C if you put the pump before, rather than after, the CPU block.
HeThatKnows said:Well obviously the pump isn't gunna dump 100 watts in the water.The point was that even the two biggest heat movers (waterblock and rad) don't change the water temp enough to worry about flow order...beyond making sure the pump has an unobstructed inlet, order's largely irrelevant.
