order of cooling
markland556
well im not 100% sure on the order of my cooling system, though some of u guys maby know the best way, heres what im thinking:
res>pump>cpu>GPU>(gpu#2 if i upgrade)>rad>res
if you have res you'll want to put it before the pump so it'll prime itself. just do whatever you gives you the shortest/easiest tubing for the rest of it.
exactly as flak said, the order doesn't really matter, you want to place things for ease of use and ease of routing the tubing. Less and better routed tubing (avoiding tight bends) will give you the best performance. And placing the resevoir right before the pump inlet will make priming the pump during filling/bleeding much easier.
That proposed order of yours looks fine.
