Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
In an orbital jigsaw, the blade moves forward a bit on the up(cut) stroke, and back a bit on the downstroke. This allows for faster cutting as well as better clearing of sawdust(more important on thicker pieces). The cuts sometimes aren't as clean, though. It's certainly not a necessity, but it is a nice feature.
I just got a corded black and decker jig saw that has a selector where you can choose orbital or non orbital and then "360" where you can spin the blade 360 degrees for super tight curves where you cant' turn the whole jigsaw around it. I have yet to use it but it's a pretty sweet looking setup.
Too bad I'm buying a house and will be modding on a "larger" scale, i.e. basement
