Options for a 3/8" block in a 1/2" loop
Fujimitsu
I've got a 3/8" block I want to use with my 1/2" pump in a chiller.
I need to know what my best option is, should I use reducers or can I just use 7/16 tubing and some worm-drive clamps?
I realize it's not great for flow but with such a small loop I dont think the difference will matter in performance, I'm just looking for opinions.
Thanks!
If you can't change the block barbs to 1/2", can you change two other barbs in the loop to 3/8"? Reducers work fine but are fugly.
I wish someone would make tubing that was 7/16" ID at one end and 3/8" at the other for just this reason. I want to add my Blitz Formula northbridge block to my loop, but the only ways to do so are very unsightly.
Excellent suggestion, if you cant change the barbs on the block you want to use, change barbs elsewhere in the loop. No need to change all of them, just the ones that interface directly to the 3/8" block. This means you will have some segments that are 1/2" and some that are 3/8" which won't be a problem, and you get to avoid reducers!
Also, dont just use 7/16" tubing unless you plan on testing whether some brand of non-conductive fluid really works!
Why not just convert everything to 3/8"? The difference in your cooling system is negligible.
Since it's attached to a chiller the only things in the loop are the pump the chiller and the block.
The pump has fixed 1/2" barbs, so I can't change them. The chiller will just be a large res so no barbs needed, the block has fixed 3/8" barbs.
I guess I'll just use reducers, insulation should hide them just fine. Gonna need to find/make metal ones though, plastic+cold = :(
I can't find them on McMaster atm, but I've seen brass barb adapters at Home Depot and just about any hardware store.
I have seen couplings but never the ones that change diameter, I'll take a look later this week though. Thanks!
3/8" can fit over 1/2" barbs with boiling water.
Or, danger den has those delrin t's with G 1/4" threads; you could get one plug, one 3/8" barb, and one 1/2" barb. About $10 with fittings i think.
