I'm looking for additional options for connecting 2 computers to the same 2.1 audio setup such that they both can play audio at the same time. This for both convenience and watching sports while gaming.
Additional info:
a) Options can include an upgrade from my Klipsch Promedia 2.1.
b) I don't have a budget limit but I want the cost to be worth it as I'm not much of a audiophile (although I probably don't know what I don't know).
c) I have space for more "stuff" but having 2 different speaker setups is a waste as 1 will be better than the other leading me to want to swap back and forth like I do now.
d) There cannot be any delay in the sound.
e) I'm in an apartment and normally sitting less than 5 feet from the speakers so I don't need something loud.
f) Computer 1 is for gaming (World of Warcraft, Starcraft) using onboard audio
g) Computer 2 is for Music, movies, TV, youtube, and anything else I do while gaming. Its the hand-me-down system and also uses onboard audio
Here's are my known options:
Option 1 Use a splitter to combine the analog sound. Haven't tried this but it would require an extender cable since the back of each computer isn't 2 inches apart.
Option 2 Analog output from 1 computer to the analog input of the second computer. Tried this and the quality is garbage. Distortion and a lot of the sound is cut out.
Option 3 Purchase a better sound card for computer #1 with better input recording options (prefer digital in if that exists).
Option 4 Purchase an audio receiver or something that will combine 2 TOSLINK outputs from the onboard sound to the single cable to the speakers. Does this exist? It would probably require buying new speakers, which I'm fine with.
Any other options?
Additional info:
Any other options?
