Optimizing Tutorial
Status
Not open for further replies.
I
Ice Czar
Guest
Optimizing Tutorial
dont mind me, this is sort of a notebook that is both sticky and locked, while I craft a tutorial
its a work in progress and there are no "bridges" inbetween the "answers" so you have to guess the questions :p
feel free to PM me with any errors you spot :eek:
(thanks Sandman)
Optimizing Introduction
To realize the full potential of your data storage, you need to understand not only the strengths and weakness of your own components, but also how your applications employ them,
where one application requires a certain access to the HDD for best performance, another may do better with the opposite
"The opposite of a correct statement is a false statement. But the opposite of a profound truth
may well be another profound truth." -- Niels Bohr
Optimizing through Partitioning
1st Click Here
That is a representation of Zoned Bit Recording, your Partition order starts at the outer edge and works inward, for the purposes of this tutorial will will say each color represents a partition (unless specifically described differently)
the concentric circles represent tracks, and the scetions within a track would be sectors
Since the drive spins at the same speed constantly there are some basic access attributes that would occur if the head\arm doesnt jump partitions to access a different part of the disk
Dark Blue, this area will have the highest density of data passing under the head for the given speed, and thus will have the best sustained transfer rate (STR), so the largest files benefit from this placement
Whereas the Innner zone (Red Section) has the fewest sectors and since the rotation is fixed, less data will be passing under the head, so it has the lowest STR
So smaller files, will do relatively well here. or files that the reduced transfer rate doesnt impact the application, like music or media that is just being read, not written in realtime.
<actively working on this descriptor >
Also the file "Density" itself can be an advantage with small files, in comparison to larger files on the outside zones, if they are truely smaller files, the number of files passing under the head could be comparible to the tracks further out, while in the representation the outer tracks have 16 sector (in reality many many more, varies with the capacity of the HDD) in the Red zone that is reduced to nine sectors, this optimization can offset the actual seek time for a given file, since that many more files would be passing under the head for the same rotation <end, >
Now if each color band was a partition any data on that partition would have to be contained to a much smaller area, so regardless of how fragmented it was, the arm and head only have to move through a few degrees of arc to seek it (the access latency), whereas a larger partition (say dark blue through green) might have a part of single file on the outside track (dark blue) and more of it located in towards the green, several degrees more the arm has to move to seek the track(s) and of course any miss with the latency of waiting for it to come around again.
If you picture those basic factors and match the type file being accessed to it you have optimized your disk (seek, latency, sustained transfer rate) that also goes along way towards explaining why keeping a HDD defragmented helps so much
and of course partitions specialized to contain different types of data fragment differently, some barely at all, others (like P2P) alot, but if they are contained, defragmenting them goes faster
Fragmentation and Defragmentation
big contigious files that just need to be accessed once and transfered will do best on the outside edge (or as close to that as possibel) having the highest sustained transfer rate
Swapfiles truely come into their own in a workstation where typically large files are being manipulated in realtime (graphics)
and they are generally located at the outside edge of the disk
review Virtual Memory in XP
so far all my links have been to the PCGuide HardDrive Section (its the one repeated as Storagereview's reference section)
But Id also highly recommend you read As the Disk Spins @ LostCircuits as it covers all of this much more comprehensively and additional nuances (like queing, command overhead ect)
also review these basic terms of performance metrics
http://www.pcguide.com/ref/hdd/perf/perf/spec/pos.htm
Access Time = Command Overhead Time + Seek Time + Settle Time + Latency
Virtual Memory in Windows XP @ aumha
Multiple Pagefiles @ Storagereview FAQ
all in all, the mantra more RAM still applies :p
Optimizing Physical Configuration
being on the same channel there are a few considerations
IDE\ATA\ATAPI is sequential
meaning first the HDD reads a part of the file until the HDD's Cache is full then writes it to the Second HDD,
then that repeats each taking its own turn
then its unlikely its reading the file from a single location, its probably fragmented, and when it writing it, its also writing it to multiple locations, that introduces the latency and access times of both drives into it
if your going to be transfering alot of data inbetween two HDDs on a regular basis, its best if they are on their own channels, writing from a HDD to a Optical drive is alot better, the optical can only deal with a maximum of 33MB/s Burst (UDMA mode2) whereas the HDD is probably at UDMA mode5 100MB/s burst (50>30MB/s Sustained), in short the sequential issues arent enought to effect the burn speed with modern software (and reads arent really an issue either) both cant saturate the bus
of course those are just interface speeds and are not the sole consideration of HDD performance > As the Disc Spins @ Lost Circuits
there is a myth about putting optical drives on the same channel as HDDs, it is just that a myth, but it keeps getting reinforced by the way Windows deals with ATA\ATAPI issues
basically with Independent Device Timing two devices (master\slave) both transfer their data at their own highest speed, but, they both either have to be PIO (which is glacially slow) or UDMA, if one defaults to PIO because of some issue, Windows will default the other as well. There was a time when CDROMs where only PIO, and HDDs where DMA, for that period of history you didnt want to share a channel, but modern opticals are UDMA mode2 so there is rarely any issue
some of the reasons a device might default to PIO
DMA Mode for ATA/ATAPI Devices in Windows XP
IDE ATA and ATAPI Disks Use PIO Mode After Multiple Time-Out or CRC Errors Occur
however if possible it is ideal
(for data integrity if nothing else)
to have each device as a master on its own channel
whenever possible consider from what source to what target the large files are being transfer on a regular basis,
and try to adapt your physical configuration to accommodate that ;)
Optimizing the File System
Optimizing RAID
Optimizing for Specific Applications
Desktops \ Games
Servers \ Database
Servers \ FTP
Workstations \ Graphics
Status
