I see everyone here w/ their amazingly high PPDs... which I can't really compete against.. but I figured at the very least, I'll try to optimize my own POS (piece-of-shit) system. Casual folder if you may
It's a personal home machine, not a dedicated folding machine. 2-3 years old.
Asus P5Q Pro LGA 775 Intel P45 ATX Mobo
Q6600 CPU with some non-stock HSF I forget (load temps are ~65 C)
ATI HD 4850 512 MB GFX Card with stock cooling
Corsair 550 W PSU
Corsair 2x2 gigs Ram (4 gigs total)
Windows Vista 7 64-bit Ultimate
I guess the first question is what type of PPD should I be seeing? I haven't actually returned a WU from this machine yet (left it running at home last night), but HEF was estimating something in the 2500-3000 range. Is this normal, or should I be able to get more outa my machine?
I followed the stickied instructions to the letter for installing the SMP client. I tried out the GPU client too. One thing I realized -- my machine can't really run the SMP & GPU client at the same time. SMP only, I was averaging 9 mins per 1% complete for a given WU. When I loaded the GPU client w/ the SMP running, I was at 1-1.5 HOURS per 1% complete. Resources show all 4 cores at 100% load though. Weird.
At the moment, running the GPU client gets my GPU temp up to 108 C, so until I get those temps lower (clean case out, get a new HSF GPU cooler?), I'm too nervous to run F@H on the GPU. I'll be running the SMP client only instead. And even if I do get the GPU temps down, it doesn't seem effective to run SMP & GPU at same time regardless.
So, is there anything I could perhaps tweak, configure differently, setup/install differently that might be able to improve my times? And also, if I had $200 to spend, what might be the best upgrade? (Two different questions, the $200 is only a "what if" before I seriously consider it.)
Corsair 550 W PSU
