Manaknight
- Jun 6, 2005
ok, i have two setups that are essentially the same, so i need some ideas for what would be the best loop for them
both are 655 pumps (one variable one non)
fuzion v2 on one and apogee gt on the other
the setups have 1x240 rad and 1x120rad one of the 120s is a thermochill, i can't remember the others at the moment, probably swiftechs
both using res and both cooling the video cards one is a dangerden full coverage and the other is a fuzion v2 gpu block.
anyway they will be cooling a q6700 with 5870 and qx6850 with either a 4890 or gtx460
my current setup has it going res - pump - 240 - cpu - 120 - gpu - res
i was wondering if there is a better way to optimize. my 6700 with 5870 both overclocked keeps it in (mostly) safe range, but not cold range. fan setup is push/pull on the 120 and push on the 240
the second system needs to have the 120 added still, but its ready to go, the 240 rad on this one is push/pull
is that the optimum config? should I double up the rad then go cpu/gpu? just curious to get some ideas when i break down the setup (going to colored hoses instead of colored water).
