Optimal angle for the side monitors with Eyefinity??
Zepharus
Ok Im looking for the BEST angle to put the 2 side monitors for eyefinity. Thoughts? Mine seems way too str8. Experts?
unless it takes viewing angle into account in the CP, I would think that collinear would produce the best (or the truest) image
hello, fish eye wants to talk to you!
the problem with setting the angles properly is it gets worse the farther the image is rendered from center.
Yes I think if you want to get truly technical with it it all depends on the game engine's curvature of the fish eye rendering, so it would be different for almost every game. I think the best way to do it is just sit where you are going to sit, then face each monitor directly at your face, so you have the best viewing angle possible on each one which is straight on.
