roshambo14
- Jul 26, 2004
Hi all. I'm hoping some of you can help me, because I have no clue what is wrong. When I remove a disc from either one of my optical drives and put another one in it, My Computer will not refresh itself to show the new disc. This makes it a problem when trying to burn a CD because the program thinks there is a regular CD in there instead of a blank one. If I click on the drive, it shows the correct contents, but the label doesnt change on the drive name, and right click > properties will also show the last disc in the drive. Only thing I have found to fix it so far is restarting, and even sometimes that doesnt work. Has anyone ran into this problem before? Its driving me nuts!
System specs are:
AXP 2600+
Asus A7V600
512MB Corsair VS
Maxtor 120GB IDE HD
Asus 9600XT 128MB
NEC 2500A DVD+/-RW
Lite ON XJ-HD166 DVD
Windows XP Professional
System specs are:
AXP 2600+
Asus A7V600
512MB Corsair VS
Maxtor 120GB IDE HD
Asus 9600XT 128MB
NEC 2500A DVD+/-RW
