I had this idea of a mod for a CD/DVD drive and a case, and I would like to know if it has done before...
NOTE: This can only be done to the top optical drive...
You cut a window in the top of the case. It should be about a 5 inchs square or a 5 inch diameter circle.
Then you cut out the top of the CD drive and make that a window also.
That way you could see the CD spinning
Maybe add a few LED's for when it's dark...
