post up when you've started OCing it.
i like to tempt fate and surf the [H] while prime is running.
zv
You mean you're not supposed to do stuff while dual primes are running? Does that cause errors?
what cooler did you get with yours?
i thought the 165 came with the 4 heatpipe cooler, but mine arrived with the 2 heatpipe cooler![]()
good thing i still had a 4pipe cooler to use![]()
For those of you picking up an opty 165 from the egg hoping to get the magic stepping I just got mine in today...CCBBE 0610. It was shipped from TN as far as I can tell. Just wanted to get everyones hopes up![]()
it doesnt seem like any one moved to AM2 ... with all the 165 threads...
Just started the overclocking...currently at 2.2 and going smoothly. I'm using stock cooling and core temp is at 54C under full load. Anyone know what a safe temp is for the Opty 165 under 100% load.
that seems really high.
mine core temp hits 60c under full load at 1.40volts and 2.7ghz
thats with the 4 heatpipe amd cooler
Coretemp reads about 10C higher than the CPU casing, and the case on my 165 is rated to 57C (TCase Max). So you're probably fine.
Mine reads 60C Coretemp (and 50C CPU temp) at full load, if I use 1.45V. I'm also on the stock cooler, but ambient temp is pretty cold here in Boston.![]()
Yikes, I'm moving to Boston in a few months. I don't like coldnessCoretemp reads about 10C higher than the CPU casing, and the case on my 165 is rated to 57C (TCase Max). So you're probably fine.
Yikes, I'm moving to Boston in a few months. I don't like coldness![]()
It was 18 this morning, but a few days ago we had all time highs of around 70. Global warming I guess. Boston's not cold like it used to be.
and that relates to a thread about a 165...how?
