Opteron 165 with XP90, high temps? Help
Dethman
I have a Opteron 165 with XP90 thermal right with a 92 mm fan over it, with AC5, The opteron is at 3.75v and clocked to 2.7, its stable on orthos for the 6 hours i tested it, but my idle temps in Core Temp are 43 core 0 and 33 core 1, In Speed fan its the same at 44 for Temp1 and Core says 35, All these with the case open
At load with orthos I hit about 63-66 on both cores, I know my cooler isnt the best, but I should be getting lower temps than that right?
3.75v. Damn. There's your problem right there. :p
If you meant to write 1.375, then I can't help you.
seems right... maybe 5-10*C check your AS to see if the IHS is warped... but temp not only goes up with vcore but also with clockspeed.
That seems a little high to me.
I had the xp90c on a opty 170 (1.5v, 3.0GHZ, DFI NF4) and idled at ~36C and loaded (prime small fft's) ~46C. I measured the temp with smart guardian.
I would check the contact between the IHS and the xp90. I have had the best results by applying a puddle of AS5 in the center of the IHS and spread it upon contact between IHS and heat sink. Make sure the the two surfaces are clean. I used acetone and then alcohol to make sure there is nothing preventing heat transfer.
well smartguardin uses the motherboard sensor and coretemp is ondie so if the OP is talking about coretemp it seems maybe 3-7*C high depending on caseflow and the fan on the XP90
if the OP is using a motherboard CPU temp monitor then his temps are inevitably higher than than stated and could be.....
Firts of all just like all of these other guys said, check your IHS and HS contact. I just got rid of my165 and had a Koolance water block on it, perfect contact and ultra low temps, due to water cooling. I sold the chip to a friend who is running swifttech water cooling, and he has the same problem you have. There was a spot between his proc and his block that was not contacting, prob cause its swiftec, but I suggested taking the IHS off and cooling it that way. For one you get lower temps anyway andtwo your proc is worth more naked. Thats what I can tell you for now, unless you really do have your shit running at 3.4 then your screwed lol. :D
LOL no 939 board in existence will go that high, heck finding a board that would do 2.0V vcore would be hard!
Im running an Opteron 170@ 2.85 with 1..375vcore. I have a lapped XP-90c and a Panaflo 92mm M1A. Ive been using speedfan and it was reporting 48c under load. I tried core temp last week and it say my load temp is 48c Core 0 and 63c Core 1.
If both your cores are the same I would check to make sure the XP-90c is making proper contact. I had a corner of mine that I couldve fit a dime under. I had to lap it to get the damn thing to sit flat.
I have to reset my IHS due to the cores being two different temps but that doesnt sound like your issue. Ive been reading on it and they dont suggest removing the IHS with the XP-90 because of the mounting brackets, I guess its real easy to crack the core. Granted that came from some forum posts I read so it definatly doesnt mean its true:eek:
