Opteron 165 OC question
ahmadmz
Hi, im at 2.6 GHz right now and i was prime testing.. after about 3h 20mins this alarm started beeping that my PWMIC is too high (65C) and if i want to shut off the computer! I panicked and stopped the test.
http://img.photobucket.com/albums/v358/ahmadmz/scr01.jpg
these are the temps at idle.. cpu goes to ~52C on load, are these ok? or should i wait for better cooling??
You should consider getting an aftermarket NB cooler and more case fans. It looks like your CPU could use a custom heatsink too, what are you using now?
Even with huge overclocks of 50% or so, Optys usually do not go above 50 degrees (under load) unless your cooling totally sucks...
chipset fan won't help lower PWMIC temps ;)
do something like this. keeps the ram cool as well :D
