Actually the overclock ceiling of X2's are generally lower than Opteron because they need higher voltage. Still though, something still doesn't seem right ... if opteron is a rebadged X2 then some X2's should have Denmark cores and and CCBBE steppings for instance.
the opty 165 and x2 toledos have shared steppings for a while now. it used to be the CCBWE code. then the famous CCBBE. it's not too crazy to think that the comparable x2s and optys are the same guts.
What I think is AMD is re-badging unsold X2 toledos
as Opty and FX-60... Other wise, being cheapo...
hmmn, that's interesting. Have never heard of an X2 with CCBBE steppings!
Could someone with that cpu please step forward?
My X2 was $300 on newegg when the 165s were ~$160
So what? It just tells me the X2 was at least $140 overpriced.
who said AMD makes logical sense when it comes to pricing at times, lol
edit:
Seriously, it's obvious that opteron is the primary choice for those in the know.
AMD can't give away X2 so they rebadge as Opteron, the hot ticket. They sell
Opteron for less than X2 (not much diff these days) but still come ahead because
it's better than no sale at all.
understood?
This thing is just blowing me away, 295 stable on both cores, at stock volts...? That beats the CCBBE hands down, from my experience.
at 100% orthos load my guess is anything over 2.7 will be difficult with that stepping
why?
this just in ...
Sunnyvale-based AMD blamed the decline on "significantly" lower average selling prices in the quarter for microprocessors, which act as the core calculating engines in computers. Unit sales were up, but were offset by the falling prices, AMD said. The company did not provide details.
http://biz.yahoo.com/ap/070112/amd_outlook.html?.v=7
Stock is currently down 11% ... TODAY.
So much for their supposed success selling X2's at higher unit prices.
See above for reason. X2's don't clock as well as 'pure' Opteron.
Sure, there's always a few exceptions.
don't clock as well? aren't the X2 folks getting 2.6-2.8 clocks?
Not nearly as easily as the 2.7 - 3.0 clocks pretty much standard on Opteron.
i don't think i'd call 3.0 clocks standard on an opteron, particularly when the majority of them are using water to get there.http://www.hardforum.com/showthread.php?t=888001
there are just as many 3800x2s + getting the same figures.http://www.hardforum.com/showthread.php?t=888001
I purchased a 165 few weeks ago, but then core 1 started failing at stock volts/speeds. Returned via RMA to Newegg, and awaited the RMA'd chip.
It arrived today:
Opteron 165 Retail Box 90nm, 2x1MB, S939
OSA165DAA6CD
LCB9E 0646 RPMW
Y974646K60461
The SOB ran all the way up to 296FSB @stock volts before taking a dump. I boosted vcore by +100mV, went to 300FSB. Added +200mV (total), and went to 302FSB before crapping out. Want to know the really cool part? Under 100% load on both cores, even overvolted..it only gets to 102F! Idle is at 96.5F. At stock volts right now, running 290x9=2610, RAM sitting at 187, HTT at 870 (may go up 1 more noth on this). Tested dual Prime95 stable while running CPU-Z, and Systool also crunching dual threaded stability test, and calculating Super-Pi at 1M positions, over and over. Ran it like this for 1/2hour, and then jumped into 3dMark06, and ran a loop for a bit. Just surfing around now, all is good. I will try to kill it overnight tonight, and figure to shoot for over 300FSB in week or so, after the AS5 cures, and some burnin is acheived. I plan to boost the volts in a few days, just to stress the silicon, to see if it opens up anymore. The CCBBE did 2700 (300x9) right away, but took max volts to be stable. CCBBE went to 235 on stock, then 265 on +100mV, then 300 on +200mV. And no, my over volt didn't kill it, check my sig for system specs. CPU temp never went over 115F. This thing is just blowing me away, 295 stable on both cores, at stock volts...? That beats the CCBBE hands down, from my experience.
