- Jan 28, 2002
I have an Opteron 165 overclocked to about 2.46ghz and the chip is running at 46C at 50% load (provided by a prime95 stress test). I think this is a little hot, considering the overclock, and the load. I have 3 fans very close to the CPU. A 120mm case fan, blowing out, a 120mm fan blowing onto the Thermalright XP-120 heatsink, and a 120mm PSU fan sucking air out of the case, through the PSU and out of the back of the case. I'm wondering if rearanging the fans will yeild a cooler overclock. What do you guys think? I can provided pics of needed.
PS: only one instance of prime95 will run so I can't push the CPU to a full 100% load.
